Perform this procedure to configure VRRP notification control.
  • Assign an IPv6 address to the interface.
  • Enable routing globally.
By default, generation of SNMP traps for VRRP events is enabled.
  1. Enter VRRP Router Configuration mode:
    enable
    configure terminal
    router vrrp
  2. Enable the VRRP-router to generate SNMP traps for events:
    ipv6 send-trap enable
Disable generation of SNMP traps for VRRP events:
Switch:1(config-vrrp)#no ipv6 send-trap enable
